VSX-AX5IS video-switching
Discussion in 'AV Receivers & Amplifiers' started by Digger, Nov 27, 2004.
  1. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    I have a problem which i hope someone may have an answer to. I have the above mentioned Pioneer receiver with DVD and freeview (Netgem) connected via component inputs. the Pioneer is outputting via component to a projector. The Pioneer fails to output my Xbox when it is connected via S-Video. I am using the official Microsoft Advanced AV Pack with supplied s-video lead. It will work if i disconnect Pio's component-out leads and instead use an s-video as the video-out to the projector...but thats a cludge i dont want to carry out each time. The manual suggests that it should work with an s-video signal...
    anyone got any ideas
    cheers
    Dave
  2. recruit
    recruit
    Digger i thought the AX5i did not upconvert to component only the new AX5Ai does that feature now!
    John
  3. Digger
    Digger
    Dec 31, 2003
    4,204
    +206
    aah...that might be the answer...but i am not convinced that i dont actually have that receiver. i will have to check the model number and get back to you.
    cheers
    dave
  4. MikeFish
    MikeFish
    Yep, can confirm what Recruit has said.
