VSX-AX3 setup problem
Discussion in 'AV Receivers & Amplifiers' started by GordonJ, Nov 13, 2003.
  1. GordonJ
    GordonJ
    Oct 23, 2000
    19
    3
    Wembley
    +3
    Hopefully someone can help me with this.
    At the moment if I play a 5.1 movie I only get sound out of the front and centre speakers, nothing from the surrounds. Everything is connected up ok and the amp has the dts/dd lights lit up when the movie plays, just nothing comes out the surrounds.
    If I set the amp to the multi channel inputs then sound comes out ok (so I know the speakers are connected/setup properly).
    So what am I doing wrong? I'm assuming the digital connection is ok as the amp correctly recognises the sound format.
  2. GordonJ
    GordonJ
    Oct 23, 2000
    19
    3
    Wembley
    +3
    Right as well as all the speakers plus dts/dd lit up I also have 'stereo' lit so that explains why the back speakers are silent.
    So, how do I turn it off :)
  3. Nike
    Nike
    Feb 27, 2001
    659
    bournemouth, UK.
    +18
    Did you get a manual with it? Might explain in there :lesson:
  4. GordonJ
    GordonJ
    Oct 23, 2000
    19
    3
    Wembley
    +3
    Manual isn't helping, shows me where the 'stereo' option appears on the display, but not why or how to get rid of it.
    The manual mentions how to switch between it's stereo modes, but not how to switch out of it :(
  5. philthyanimal
    philthyanimal
    to get out of stereo, press the movie button, then enter. then select your format.(unless its dts or dd5.1 then its selected for you). Make sure you press the button with the green stripe under it first though, thats a kind of shift key.
    Don't worry about this, i kept doing it to mine.
    Have you set up the 4 digital ins correctly on the amp?
    Once you get it going you won't be disappointed, believe me, it sounds awsome.
    What speakers you got?
  6. GordonJ
    GordonJ
    Oct 23, 2000
    19
    3
    Wembley
    +3
    Yay sorted, thanks Philtyanimal. I was being clueless and not hitting enter after selecting the movie mode :)
    I'm still using my 5.1 setup mission 77's at the mo, there'll be the next part of the upgrade.
  7. gudjong
    gudjong
    Mar 6, 2004
    12
    Iceland
    Just had this stubit problem too. for days
    grgrgrgr
