VSX-924 LG simplink changing AV source to TV
djrobmac
Really researched this as much as i can and although a lot have asked the same question I've not found a suitable reply.
I have a brand new LG 4K OLED EF950V and a pioneer VSX-924. Whenever I turn on the TV the amp turns on as it should but after a few seconds it changes the AV source on the amp to TV so I have to get up and put it onto the Sat HDMI channel to get the pic back. Volume all working fine, its just the changing AV channel thats perplexing me. Was fine with my GT50 Panasonic.
Roohster
Check to see if HDMI CEC is enabled... if it is, switch it off.
djrobmac
Without simplink (HDMI CEC for LG) enabled the amp won't come on with the TV and the TV won't control the the receivers volume so thats not really what I'm looking for. Had no issues with Viera link and my old panasonic. Anyone else figured this out?
dante01
What you are experiencing is a common flaw with HDMI ARC. ARC uses HDMI CEC for its functionality, but a byproduct of this depenence upon CEC is that the TV causes the receiver to default to its TV source when powered up. There's no real solution to this other than to not enage ARC, but there is a workaround if you've a Harmoony remote. The workaround is outlined here:
Denon AVR X2000 Power on question
Although relating to a Denon receiver and an Samsung TV. the issue is the same and caused by HDMI CEC and ARC.
djrobmac
Thanks for that dante01. Real pain in the butt considering the old Panasonic worked flawlessly. I wonder if another make of AV receiver would fix the issue.
djrobmac
Well, what can i say, you have mistakenly fixed my problem!!!! In that thread you mention about a sky firmware update:
SKY recently updated their firmware to give them HDMI CEC (Control) so I'd suggest looking within the STB's settings for a setting that you can turn this off onboard the SKY STB with.
Sky Help: HDMI One-Touch-Play
Would you believe that turning HDMI Control and the HDMI Control via RF Output on has actually fixed the problem completely. Now if I just press the sky button on the remote control (or power button on the LG remote) it switches on the TV, the AV Receiver (which as we know then gets told to go to the incorrect TV input by the LG TV) but the sky box now says bugger that and forces the AV Receiver to the correct input all without me having to do anything!
Spent countless hours trying to figure this, you're a genius!!
dante01
Nope. I simply mentioned something that lead you to discover a resolution and I didn't actually solve the problem for you myself. Anyway, glad that you found a solution :)
djrobmac
Nope. I simply mentioned something that lead you to discover a resolution and didn't actually solve the problem for you myself. Anyway, glad that you found a soution :)
either way you have cheered me up no end and probably saved me a ton of money changing my setup. THANK YOU!!
