VSX-922 Speaker B volume
Discussion in 'AV Receivers & Amplifiers' started by hornetster, Feb 19, 2014.
  1. hornetster
    hornetster
    Jan 5, 2014
    30
    9
    Elliott Heads, Qld, Australia
    Usiing the Speaker B option on this amp, but the volume is very low, compared to the speaker A.
    Is there any way to alter the relative volume? ie turn the speaker B volume up compared to speaker A.
    Trouble being that the areas are fairly close, and in the speaker B area, it's actually difficult to hear the B speakers, when the A speakers are also on.
    Thanks.
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    What speakers do you have in each area?
  3. hornetster
    hornetster
    Jan 5, 2014
    30
    9
    Pioneer VSX-922 - Bose 5(?)01 in the main area, and just a pair of (reasonable) external speakers in the 'B' area.
    Used to be fine ()volume was comparable) with my previous Denon amp...
    Thanks.
  4. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,440
    What are the sensitivities of each speaker? What impedance are they?
    Did your Denon have A/B speakers or did you use a Zone 2 feature? Is the Pioneer using an A/B system or a second separate zone?
    Are you using it to play the same source in each location.
  5. hornetster
    hornetster
    Jan 5, 2014
    30
    9
    A/B on the Denon, A/B on the Pioneer, just using the same source.
    Just want to know if anyone knows if there is a way to control relative volumes....?
