vsx 912 trouble with sub
Discussion in 'AV Receivers & Amplifiers' started by sime, Jul 23, 2004.
  1. sime
    sime
    Jul 7, 2004
    142
    +6
    ive just set my first receiver up today(vsx d912)even though i am blown away with the sound i have only got one small problem with the sub i cannot seem to get it to work i have connected mission m30 to the front and rear and also a mission centre,but my sub is a acoustic solutions as money was running short.so i thought i'd use my old one from a speaker package i purchased last year. is it possible to run this it as a built in decoder and model number is 1033. its only for a couple of weeks or so
    any advice would be a great help ! :D
  2. Anastie
    Anastie
    Jul 15, 2003
    1,960
    63
    UK
    +208
    Cant recall the details but I had a similar problem got an answer on here. There is a setting to allow the sub to "stay on" double check the manual.
    Hope that helps
