VSX-1016v 4k capable? budget 4k reciever options
Discussion in 'AV Receivers & Amplifiers' started by lukeysl, Jun 14, 2018.
  1. lukeysl
    lukeysl
    May 3, 2016
    34
    9
    Essex
    hi guys, bit of a noob on the home AV front and struggling to get answers I need online.
    in a panic as the VSX 1016v I have running my HDMi / 5:1 currently I'm unsure if it will work with 4k
    I'm about to get a 4k screen and sources will be Sky Q and Xbox One X HDMI & feed the Bose Cube speakers, sub, center speaker. I speced a decent screen for gaming etc and knew I needed decent cables but just paniced the receiver will be the stumbling block!!
    recommendations on the budget end to replace with 4k? If I need to? I found the Pioneer VSX 531 on Amazon seems ok, again tho if there is a 2 source version is happily pay less.
    noob questions I know, sorry
  2. dante01
    dante01
    Mar 5, 2009
    43,430
    +9,965
    No, The VSX1016 predates the HDMI version needed to facilitate HDCP 2.2 compliance as well as the ability to passthrough 4K 40/60Hz video.
    The Pioneer VSX531 on the other hand is fully HDCP 2.2 compliant and can passthrough UHD encoded 4K video sources with a frame rate of up to 60Hz.
  3. lukeysl
    lukeysl
    May 3, 2016
    34
    9
    Essex
    thanks @dante01 really appreciated. I thought as much from its age but wasn't sure.
    so the VSX531 is about my top end of my budget. Is that spec OK for Sky Q, and Xbox One X 4K?
  4. dante01
    dante01
    Mar 5, 2009
    43,430
    +9,965
    The VSX531 is fully compliant with UHD 4K/60p/4:4:4 pass-through with HDCP 2.2 compliance. THe downside is that it only includes support for HDR10 and will not passthrough Dolby Vision or HLG HDR.
  5. lukeysl
    lukeysl
    May 3, 2016
    34
    9
    Essex
    thanks again, if I'm honnest I don't k ow what Dolby visio / HLG HDR are!! Is that something id miss on a Sky Q main box?
  6. lukeysl
    lukeysl
    May 3, 2016
    34
    9
    Essex
    my next question is I've read they dont have auto calibaration. As a bit of a noob is that going to be a big issue.
    my old amp did have that. A little mic I plugged in and it did its magic.
    read a review on the Yamaha RX-V379 that this does have auto calibration but they are quite a bit more pricey
    will the 531 have steps to calibrate manually a relative newbie can follow?
  7. dante01
    dante01
    Mar 5, 2009
    43,430
    +9,965
    What's your budget for the receiver?
  8. lukeysl
    lukeysl
    May 3, 2016
    34
    9
    Essex
    if I'm honnest needing an upgrade came as a surprise so I'm looking for as cheap as possible that will do the job. But also do wanna avoid stress. I guess £200ish but happy to listen to all advice for my setup from people that know!
    I'm not after pin perfect cinema experience, but just want it right / working you know.
    inputs are - Sky Q, Xbox K
    speakers - 4 x Bose jewell cubes corner mounted, eltax sub and just ordered a Dali Zensor Pico Vokal Centre Speaker.
    Sony Bravia 55"
    its all a bit piece meal as just been working with what I had for the budget etc I know not ideal.
    really appreciated.
