VS8 failed to convert Video file - NTSC
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by BrianH, Dec 9, 2004.
  1. BrianH
    BrianH
    I have a number of projects which I have successfully created Image files for in PAL format, when I change the format to NTSC during the conversion process the following error message comes up. "Failed to convert video file Error: 80041c21 ....." It appears to occur when converting one of the large clips as if I move this clip earlier in the series the erro message occurs earlier in the conversion.
    Has anyone else encountered this problem?
