FadgewackeR
I'm a bit stumped as to why my GX is saying VRR is not supported in the video output info screen - anyone got any ideas?
I haven’t an LG but, based on my Panasonic, do you need to enable VRR within either the HDMI settings or picture preset settings on your TV?I'm a bit stumped as to why my GX is saying VRR is not supported in the video output info screen - anyone got any ideas?
Same on the lg c9. I also don't like the allm popup every time I start the console, start a game and again if it changes HDR/SDR/120hzSorted it, but I don't like it... Had to turn ALLM back on on the TV. I turned it off as it was annoying me every time the PS5 started, as I already have everything to start up in game mode etc, and being in ALLM was making the screen flick in and out of HDR on start-up, which didn't seem necessary.
Anyhow - that fixed the VRR issue.
Yet my C9 doesn’t support VRR apparently? Although I did notice a new option for Dark Fine tuningI have an LG B9 and Spider-Man Remastered works perfectly in 40 fps 120 Hz mide with VRR enabled.
True.Some folks might have to enable ALLM instant game response and hdmi deep colour for it to work
got to say im pretty confused by VRR i know what it does and what the benefits are supposed to be. Digital foundry talking about elden ring on 60hz output instead of setting it to 120hz confused me. VRR range would then be 48 to 60 not 48 to 120
and with xbox you can get the vrr range to work from 20 to 120 but im not supposed to set my xbox to output to my tv at 120hz output because of persistence blur? and i wouldn't want to engage VRR because i couldnt implement black frame insertion i dont even know if ive got that on or where it is on my tv? is it on or off in game mode on LGCX
Ah, I'm playing Cyberpunk 2077 at the moment and ray tracing mode supposedly runs at 30fps, but my LG TV is telling me it's running at 60. It is playing very smoothly, whether that's down to VRR I don't know, but the game settings shows that VRR is on.
Indeed, which is baffling considering they've an AMD processor under the hood. So, why not us Freesync?!technically sony have implemented VRR to the standard HDMI forum specification
