VRO files
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dade, Dec 18, 2004.
  1. Dade
    Dade
    Is there any software out there that will allow me to write VRO files? I want to copy video from my PC on to DVD-RAM so that I can play it on my Panny E55. Is this possible?
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    711
    46
    Northumberland
    +247
    I don't have the answer to your question at the moment and would be interested to find out.
    I use DVD-RW discs for this purpose (burned as normal DVD video files using Nero 6) and these play back fine on both E55 and E60 machines.
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I've heard WinDVD Creator 2 can create vro files. It supports DVD-VR format which is actually the format that produces the VRO files.
    You may want to give the free trial a go and see if it does what you want.
    good luck
    steve
