.vro files on pc
Discussion in 'Blu-ray & DVD Players & Recorders' started by grayt60, Oct 13, 2004.
  1. grayt60
    grayt60
    my problem is the play back of these files in win xp
    after a couple of mins the screen splits into 3 screens all corrupt
    i use ram drive to get them to pc
    they were originally video 8mm camcorder tapes recorded on to my dmr-e30
    i cannot find a solution up to now and they playback perfectly well on the panny.
    thanks any help much apprieciated
    grayt
  2. sweat100
    sweat100
    Why not you use a different player to play. I am using window media player 10 to play and got problem playing them as well. I use Power DVD player and by far is one of the best player i had. They can recgonise that it is a dvd-vr disc and can select the different menus, just like the disc navigator on the panny.
    An alternative, I never tried before, why not you try changing the file extension from .vro to .mpg, since they are essentially the same, only vro is a mulitplexed file. Maybe windows media player can be "fooled" to think it is a mpeg file. If it works, let me know? :)
  3. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    I use Win DVD 4 and this also happily plays back VROs from RAM discs recorded on an E55.
