Vr Lens
Discussion in 'Photography Forums' started by martin99, Sep 2, 2007.
  1. martin99
    martin99
    Sep 23, 2004
    290
    Surrey
    +15
    I cant decide between the 55-200 and 70-300 Nikon lens for my D40.
    Can anyone help!?
    cheers
    martin
    PS: Only other lens I have ATM is the 18-55.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,955
    Manchester, England
    +84
    what about an 18-200VR?
  3. Fozzybear
    Fozzybear
    Dec 10, 2005
    1,871
    83
    +295
    If you can afford it the image quality of the 70-300VR is supposedly worth it over the 55-200. The 55-200 is more compact but the 70-300 is more useful for wildlife and so-on, having quite a bit more reach.
  4. martin99
    martin99
    Sep 23, 2004
    290
    Surrey
    +15
    seems expensive when I have an 18-55 already, i also fancy 10-20 and a macro lens. so while cost is not the prime consideration it is important.
  5. SignalMan
    SignalMan
    Mar 8, 2002
    349
    West Yorkshire
    +22
    I've got the 70-300 VR and it's a very versatile lens :smashin: Will be taking it to Nurburgring this coming Friday for some Motorcycle action shooting where the 300 reach will help :smashin:.
  6. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    Martin99 - What do you expect to shoot with the lens? - I had an 18-200mm for a while but found that 200mm wasn't enough for subjects such as zoo animals / ducks across the canal etc - I have a 70-300mmVR & it is very good but as you say quite a bit more than the 55-200mmVR - If you're happy you don't need/want the extra reach then go for the 55-200mm ... Paul ;)
  7. martin99
    martin99
    Sep 23, 2004
    290
    Surrey
    +15
    mainly sports. One that does worry me is how good is the salt water resistance of these lenses? I spend a fair amout of time at the beach, Kayaking, surfing and fishing etc. and while I'll do my best to keep the lens dry, I've seen what the salt air can do to metal.
  8. PaulBoy
    PaulBoy
    Jul 14, 2000
    1,735
    Surrey UK
    +87
    Don't get it wet! It might not look too cool but I'd even wrap it in a carrier bag on the beach when shooting there - There will of course be a "proper" waterproof cover you'll be able to buy - Maybe someone here can point you in the right direction (?)
    Paul ;)
