VP50 Serial Cable Question
Discussion in 'Projectors, Screens & Video Processors' started by Oblomov, Sep 18, 2007.
  1. Oblomov
    Oblomov
    Nov 21, 2004
    273
    +8
    Please can anyone tell me if the RS-232 serial cable needed to upgrade the firmware of the VP50 is straightwired or reverse wired? I believe that the latter would be classified as a null modem cable but it is best to check!
    Apologies for the banal question.
  2. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
    It is wired pin-to-pin, not a null-modem type.
    Regards,
    Ian
