Vote for a Sub 1K Prog Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by ispeed40, Jan 9, 2003.
  1. ispeed40
    ispeed40
    Im interested in what the favourite is for a player under £1000.
    This is my budget (honest) which im going to stick to, so any advice on the best model would be appreciated.
    I have a Panny Plasma TH42PW5B being delivered tomorrow, to couple with the new DVD Player.
    Speedy
  2. jmack
    jmack
    i have a philips 962sa prog scan which i`m very happy with but if i had
    1 large like you too spend i would get a arcam dv88p i think its called
  3. juboy
    juboy
    Would think your best bet is the Denon 3800 with the new/most recent firmware update. This will give you PAL and NTSC progressive scan and DVD-Audio, if that's of any interest to you.
    It can be had online for under £800 (Multi-Region), leaving you some cash for decent component cables and a few shiny new DVDs :)
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
  5. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Marantz DV8300 buts its 100 quid over yr budget.
    Toshiba SD900E £699 @ leconcepts, superb but no pal progressive.
    The Marantz wipes the floor with the Denon 3800 in Januarys Hi Fi choice mag review.
    Arcam DV89 soon
  6. juboy
    juboy
    Which mag? I have the Jan 2003 Hi Fi Choice in front of me and there's no mention of a Marantz DVD player review.
    The Denon 2800 MkII did however win their DVD player group test £750 to £1200 .
  7. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    using most of your budget I would say the following should be looked at/auditoned and then you can make a better choice...
    Denon DVD-3800
    Arcam DVD88+
    Toshiba SD-900E
    Personally I would go for the 3800 as 'overall' I think it is the best player IMHO...
    JJ
  8. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Doh two F***ups in as many minutes :(
    Could be Feb Issue, I work for a newstrade distribution co. and was flicking through several mags this morning at work.
    Could of been Stereophile Guide though Jan products of the year issue.
  9. juboy
    juboy
    Obviously not enough coffee yet this morning :)
