Volume setting?
Discussion in 'AV Receivers & Amplifiers' started by filipe, Jul 11, 2001.
  1. filipe
    filipe
    thanks for the above replies.
    refering to the second one:
    Does it mean that when in AV with the mentioned set up the arcam would control the front speakers volume, while the Sony AV controls the other speakers volume level?
    How would I set the correct volume in the arcam Amp?
    Out of curiosity, regarding only the AV performance, is there an advantage in using the arcam stereo amp front speakers rather than the Sony AV amp?
    Fil :eek:
  2. filipe
    filipe
    OOPS...
    The above post was a reply to the post titled "AV Processor" (Posted by Filipe)
    :rolleyes:
