Volume Question
Discussion in 'AV Receivers & Amplifiers' started by hutchingsp, Jan 15, 2003.
  1. hutchingsp
    hutchingsp
    I've just got a new receiver, a NAD T741.
    Until now I've only ever had amps/receivers with "7am to 5pm" hard volume controls (by Hard I mean the knob would stop turning).
    The NAD has a freely rotating volume control, the minimum volume is -61db, not sure of the maximum. A normal listening level seems to be around -18db.
    I have no idea how hard I'm driving the thing as the numbers mean nothing to me - for example, if the scale starts at -61, by implication will it go to +61?
    I've mailed NAD (Lenbrook) as I've found their service department to be very helpful, I thought it would be a good idea to ask here as well.
    regards
    Paul
  2. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    When the volume control is setup to display db's, 0 is the reference level i.e. the level before the amp starts to distort the sound and for AV receivers should be factory set to 75db which is bl**dy loud. They are often not set right so you should set it with a sound pressure meter to get all the speakers balanced properly.
    Don't worry about driving it to hard just has long has you don't start going high into the +db's and even then I don't think you would need to worry to much about your setup, just your neighbours :D
    I don't think your amp will go to +61, mine which is a Marantz goes from -61 to +15 so its not has simple has -61 to +61 like I said 0db is the reference level with -61 on your amp being silent, so you should really treat max has 0db which should equate to 75db all things being set correctly.
    Hope this has helped rather than confused you ;)
  3. kennrc
    kennrc
    Interesting discussion...
    I have a Sony STR-DB1080QS which starts at -100db and tops out at 0db. Thus I can't go into the + range.
    Is this uncommon ?
  4. russraff
    russraff
    Aug 1, 2000
    2,415
    Newcastle
    +63
    Most amps that I have used go into the "+" range by a few db's. That is unless the speaker gains have been increased. The NAD T770 that I had rolled back the absolute max by the amount of gain increased on your speakers. Perhaps this is why your Sony doesn't go past 0db?
    I suppose it doesn't matter anyhow, as long as you can get to the required volume without distortion.
    As for driving the amp hard, I dont think you are. The db is just another way of displaying volume. The A1SE that I heard was set to -15db in a fairly average room.
    Russell
