Volume on Rear Speakeres
Discussion in 'AV Receivers & Amplifiers' started by dp600, Aug 25, 2006.
  1. dp600
    dp600
    I have a Denon avr-1906 reciever and used the auto set up.How can i turn up the volume on the rear speakeres but leave the otheres the same ??.Thank You.
  2. Jase
    Jase
    Mar 16, 2001
    10,862
    United Kingdom
    +2,877
    On the remote press the CH Select/Enter button and cycle through until you get to SL, SR etc. When you get there use the left and right arrow buttons to adjust the channel levels up or down. The change will only affect the mode that you're in. If you want to change the channel levels for ALL modes you'll need to access the main setup menu and adjust the channel levels from there.
  3. dp600
    dp600
    Thank You.
