volume on optical
Discussion in 'AV Receivers & Amplifiers' started by Elektron, Dec 28, 2003.
  1. Elektron
    Elektron
    I am tending to find that now i have my system set up and playing a dvd I have to turn the amp up quite along way to get the voulme to a reasonable listening level. ie on the tv connected via audio jacks the amp level is about -65db but when using the dvd connected via optical it has to be about -37db. is this normal or am i missing something?
    Setup
    Yamaha DSP-RX640SE amp/processor
    Yamaha S530 DVD player
    Yamaha 10MM Speakers X4
    Yamaha NSC-80 Centre speaker
    Yamaha YSY-SW40 Sub.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    have you tried the dvd connected in any other fashion? It is possible simply that the level coming from the tv is high, that wouldnt really surprise me
    ad
  3. BenPremium
    BenPremium
    Nov 23, 2003
    330
    16
    Hmm, how come I have to turn my Denon up to -10 or higher when I'm listening to DVDs? Am I doing something wrong? :|
  4. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    397
    sussex
    +61
    Ben - my denon's usually cranked to about -15 to -20, don't worry just sit back and enjoy!
    M
  5. Nobber22
    Nobber22
    Jun 6, 2002
    2,979
    Berkshire
    +110
    It's normal. Telly broadcasts & CD's tend to be about 15% louder than DVD. Just turn the amp up until you are happy with the DVD volume. :)
  6. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,312
    Somewhere in South Yorkshire
    +5,667
    The sound level from DVDs - the discs themselves - is often 'lower' than from other sources. Because the dynamic range is so great (compared with TV, say, where it is compressed).
  7. JAMBO
    JAMBO
    My Sky+ is connected to my Pioneer amp with both analogue audio cables and optical digital toslink. Before anyone asks why.... I initially had basic Sky connected via audio leads, when I upgraded to Sky+, I used the optical digital connection for the Sky Movies Dolby Digital output. Since I now had a spare set of audio leads and spare inputs on the Amp, I decided to connect both ways for comparison. Obviously, these are both from the same source to the same receiver, but still give a very noticeable difference when you switch from one to the other..... the analogue connection being much louder. Although they both show the same db reading on the amp, the sound from the analogue audio leads is about about 10db higher than the optical digital.
