Volume on iRiver iHP 140
Discussion in 'Hi-Fi Stereo Systems & Separates' started by ahh, Jul 25, 2004.
  1. ahh
    ahh
    Oct 13, 2003
    84
    London
    I find that the max volume setting on the iRiver is a bit low for some tracks. Has anyone else come across this problem?
    Is there a software fix for this? (as available for an ipod?)
  2. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +286
    You could try a different firmware version - apparently the European firmware has volume limitation in order to comply with EC safety regulations. I haven't needed to do this myself so I can't tell you the ins and outs but you should try searching http://www.misticriver.net/ for more info.
    Gav
