volume of the denon 550sd?
Discussion in 'Home Cinema Buying & Building' started by KennyMo, Mar 8, 2005.
  1. KennyMo
    KennyMo
    hi,
    i just received my denon 550sd home theatre kit.
    can anyone (who also has this system) tell me if the volume only gets loud around the 0db to -10db mark?
    i find it really quiet from -60 up to about -10db.
    are there any settings in need to change?
    kenny
  2. Pugs1
    Pugs1
    Jan 31, 2005
    1,324
    +225
    You need to go in to system setup and setup the speaker channel volumes to say 10 db. That will do the trick
  3. KennyMo
    KennyMo
    THAT'S DONE THE TRICK!
    sorry my ears are ringing from the adjustments.
    cheers for that.
    another question:
    are the speakers on the dht550sd magnetically shielded? does it only affect crt's or lcd's as well?
  4. Pugs1
    Pugs1
    Jan 31, 2005
    1,324
    +225
    Yep, don't have to worry :thumbsup:
