Volume Levels
Discussion in 'Home Cinema Speakers' started by Mwillo, Apr 27, 2002.
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    Newbie Needs Help..........
    I am just about to finally set up my Marantz SR6200 Properly(i ve just plugged it in and left everything set at default until i had the time to run the speaker cable.)
    But was just wondering is there a rule for setting the volume levels on each speaker.
    Or do you have every thing set the same.
    Sorry if this is a dumb question but well...........im dumb.
    Mark
  2. Geoffc10
    Geoffc10
    Every speaker should output 75 db. You can use a SPL meter to do this. Or you could use the Ultimate Platinum DVD setup disc. I'd use a SPL meter. I was lucky in that i borrowed a SPL meter from work!
