Volume levelling advice Sony STR-DH820
Discussion in 'AV Receivers & Amplifiers' started by byron_hinson, Jan 9, 2012.
Tags:
  1. byron_hinson
    byron_hinson
    Aug 23, 2002
    1,775
    United Kingdom
    +247
    Has anyone got any suggestions on how to level out sound on my Sony str-dh820 av receiver. When switching channels some seem to be much lower in volume than others, especially any which output Dolby sound.
    I've tried the auto volume button on the remote and although I like that option, my wife finds that too loud! I can't win!
  2. PSM1
    PSM1
    Dec 20, 2008
    26,266
    +5,423
    Is this changing channels on the internal tuner of the TV or Sky or is it different volumes from different sources to the receiver?
  3. byron_hinson
    byron_hinson
    Aug 23, 2002
    1,775
    United Kingdom
    +247
    Different channels on virgin TiVo.
  4. dante01
    dante01
    Mar 5, 2009
    44,865
    +10,538
    This is due to the wider dynamics of Dolby encoded material in comparison to the lower bit rate PCM encoded audio used for the non digital channels. There's not an aweful lot you can do about it, but your amp may have some form of adaptive dynamic range control or other such mode it can utilise to lessen the problem?
