volume distortion level ?
Discussion in 'Arcam Owners' Forum' started by deaf cat, Apr 10, 2005.
Tags:
  1. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    The AVR200 goes up to volume level 80 I believe, I have had it up to 65 and sounds fine and loud!
    Just wondering if it starts clipping further up or is 80 the max with a clean (rms) no distortion signal ?
    Don't really want to send any clipping to my speakers at that sort of volume level, thinking it will damage then quite easily....?
    (Speakers - Ditton AV3 4ohm 200W max 150W continuous)
    Any comments much appreciated
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    If you plan on running it loud then I would get some better power amplification, the P7 or new P1000 would be viable options.
  3. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    So if I had a Rega Maia3 with the fronts bi-wired from it, is the pre-amp of AVR200 going to stay clean right up to 80, or will the quality fade before the rega starts to clip ?
    Or is it safe to gradually turn it up untill I dectect something is not right :eek: ?
    ( :hiya: whats the spec of the P1000?)
  4. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    As far as i understand you can continue to turn up the volume until you begin hearing distortion either through the speaker drivers going past their designed excursion limits or by the amp clipping
  5. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    The actual setting of the volume control when using an analogue source has no relationship to the maximum power output/clip point, since it depends on the level of the input - you can cause the amp to clip with the volume set at 50 if you drive it with a high enough signal.
    With a digital source, I believe Arcam design for rated output at a volume setting of 80dB with a 0dBFS signal (digital max - impossible to record a higher level than this).
    The amp can probably go a bit higher before it distorts significantly, or clips. Depends on the PSU voltage and current ratings.
  6. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    So with a digital source/input, its probably safe to keep on turning up all the way to 80 and we should be safe?
  7. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    I think we have to leave it to Arcam to comment on that!
  8. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    sounds like a plan to me...
    Is there any way to attract Arcams' attention.....?
  9. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    they browse the forum when they can though obviously they are fairly busy people so if you want a direct answer either email them (which from past experience often takes around a week to get a reply) or preferably phone them - where i understand their support is top notch.
  10. deaf cat
    deaf cat
    Feb 9, 2005
    1,224
    48
    +58
    cheers I'll give em a bell
  11. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    On the two occasions I've e-mailed their tech support (most recently last week) I've had a response within an hour or so, so maybe they've improved that area to match the phone support.
