Volume difference between TV and DVD
Discussion in 'AV Receivers & Amplifiers' started by harrison99, Dec 16, 2004.
  1. harrison99
    harrison99
    I have a Denon 770SD amp connected to my TV (for audio out from the TV via R+L audio cables) and my DVD (via an optical digital cable).
    The TV is much louder than the DVD at the same volume level on the amp. Does anyone know if this is usual or fixable?
    Many thanks.
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    This is normal. DVD's are 'quieter' due to the compression on the disc.
    Nothing to worry about.
