volume control sky/Tosh all in one
Discussion in 'Sky Digital TV Forum' started by cappo, May 27, 2005.
  1. cappo
    cappo
    Oct 16, 2004
    62
    Liverpool
    Hi all was wondering if it is possible to control the volume from my tosh SD-43HK through my sky remote as havin to use 2 different remotes is a real pain as my daughter finds it amusing to play with them.
    plus has anyone had any experiance with the sd63hk - is it worth upgrading??
    thanks for looking .........
    :smashin:
  2. RichA
    RichA
    Apr 28, 2005
    49
    11
    Putney
  3. cappo
    cappo
    Oct 16, 2004
    62
    Liverpool
    did you get yours set up m8? says on satcure >
    Question
    >My system operates via a Yamaha RXV795 Amplifier,
    >would you know if there is a 4 digit code or some other way to make the
    >Sky remote operate the Volume control on the Amp?
    >Question
    >Will the Sky remote operate my microwave oven / car alarm / Hi-Fi / garage door / DVD player etc?
    No. The standard Sky remote is designed to operate the Sky Digibox and many (not all) TV sets. IT WILL NOT OPERATE ANYTHING ELSE.
    have googled but not found anything upto now, must be other poeple out there with same problem/solution
    :confused:
  4. John
    John
    Dec 13, 2002
    11,193
    +2,829
    Check out www.hummer.co.uk .
    There might be something in the SKY section . My Sky+ remote operates the TV and sound on my amp , as well as all the SKY+ functions
    Atb
    JS
