voipuser.org the community group
Discussion in 'General Tech & Gadget Forums' started by mucca_D, Sep 5, 2005.
  1. mucca_D
    mucca_D
    Jan 31, 2005
    1,881
    116
    +522
    http://www.voipuser.org/
    Is a community run project and is FREE.
    What you do is sign up for a sip account. This gives you the normally VOIP to VOIP calls but also gives you a PSTN number that anyone can use to call you.
    You then register for an 08700 (there are others) which you give to people to ring you or anything you can think of to get poeple to ring it (legite ways please)
    The telco gives a kick back into the community pot of minutes for all to use (about 73,334 atm) this then alows you to make calls out form your account for FREE.
    You get an account meter and as long as you are putting minutes in then all is good, if you take to much out then you get restricted.
    All in all its very good and a good community on the forum
    Ta
    Mucca_d Bagpuss on voipuser.org
