VOIP wireless router?
Discussion in 'General Tech & Gadget Forums' started by scw, Sep 5, 2005.
  1. scw
    scw
    Jan 6, 2005
    212
    +4
    Can anyone recommend a VOIP compatible wireless router for use on ADSL broadband, on a BT line, so that I can use my existing phones to make landline or VOIP calls, as well as share my broadband with more than one PC?
  2. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,135
    9
    13
    CyberSpace
    +10,673
    I use a Linksys WRT54GS, works a dream....Very expandable and good Internet support community....
  3. mucca_D
    mucca_D
    Jan 31, 2005
    1,881
    116
    +522
    SpeedTouch 716v5 ADSL IAD (combined) Review
    gets very good reviews
    Zoom do a few (ebuyer sell them) and have a few good reviews to, and they are very cheap
    HTH
  4. JayCee
    JayCee
    Jan 20, 2004
    22,311
    Lanarkshire
    +2,324
    Netgear DG834GT.........The main PC connected by a network card and 2 PC's and my HP iPaq Pocket PC wirelessly.
    VOIP on the main PC and the Pocket PC version of Skype on the iPaq. :thumbsup: Works like a dream.
  5. scw
    scw
    Jan 6, 2005
    212
    +4
    Thanks I’ll look into those suggested…any more?
  6. the_sanguine
    the_sanguine
    Jul 31, 2003
    1,176
    38
    +7
    I'm looking at the Netgear. Amazon is the keenest price I can fing. Dunno if it's V2 or not though (what's the difference?)
  7. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Draytek Vigor 2600VG - has two VOIP ports and is very good at handling ADSL where there is high attenuation (usually on long lines)
  8. telboy
    telboy
    Jan 24, 2002
    55
    Kent
    Try a Billion 7402VGP, very popular in Australia
  9. pilotsnipes
    pilotsnipes
    Vigor 2600VG. What a great machine. Serious. Esp if you're in the UK
  10. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    I use a Netgear DG834G V2...VoIP plugged ditectly into the router so i have free calls without having to boot up a pc.
  11. RekalinSimms
    RekalinSimms
    I have SunRocket here in the States, and use a Linksys WRT54GS which works really well. I've been really happy with the service and the router.
  12. mkjustuk
    mkjustuk
    Mar 4, 2002
    455
    Cheshire
    +14
    Does anyone know if the BT badged Voyager 220v can operate a VOIP service other than BT's own?
  13. Steviemacca
    Steviemacca
    Have had a quick search through the various threads but can't find no mention of it. I have a Linksys WAG54G but have tried and tried to get VOIP to work but no success at all. Anyone know if this router is compatible?
    Is anyone aware of any reason VOIP wouldn't work on a Wanadoo Broadband connection in the UK?
    Final question....if I have VOIP and a bluetooth connection on my pc can I use a bluetooth headset to receive/make calls?
    Thanks for your help:thumbsup:
    Steviemacca
  14. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    36,135
    9
    13
    CyberSpace
    +10,673
    There is no such thing as a router being incompatible with VoIP...Well not very likely....The problem you might be encountering could be related to opening up port numbers. Most VoIP application run at a certain port number so they can listen to incomming traffic etc....It all depends on the service you are using, the application that you are using what port numbers need to be enabled etc.....
    In addition if you use a PC connected to the router, you may have to enable the port numbers on the PC as well.....And enable some forwarding on the router as by default most block of visibility of anything inside your network.....Any reputable VoIP provider has got a manual which clearly states the steps you have to make for their service....
