Surreywinter
Im looking at converting the phones in my house to a VOIP system. Right now I have a conventional BT line coming into the house into a master socket. A number of conventional phone lines (3) come off the master socket, disappear into a number of conduits and re-emerge in a number of other rooms. The conduits are all known and wide enough to re-wire if needed. Some of the phones in the rooms are fixed lines while one is a wireless point off which a couple of hands-free phones are run. Probably a fairly classic setup.
What Im looking to do is put a VOIP system in fairly close to the master socket which is where my PC router sits. Id then like to plug my existing phone lines that currently come into the back of the master socket into the back of the VOIP system to make the existing phones VOIP. Id also like the option of hanging a backup phone off the BT master socket and if possible having the option to switch all of the phones back to conventional without much disruption (a switch would be ideal) if there was a VOIP problem.
Id also rather keep my home wireless router running my home PC network rather than replace it although Im not completely set on that. Main reason being frankly that it works fine and Im loathe to replace something that works fine!
This seems to me to be a fairly classic setup but Ive not been able to find any FAQs or the like that address this approach. Is anyone aware of anything that could help me understand how this could work?
