Voice recognition Systems? Integration?
Discussion in 'Home Cinema Buying & Building' started by DannyD4315, Apr 28, 2007.
  1. DannyD4315
    DannyD4315
    Apr 28, 2007
    547
    +6
    Hi all,
    Just after picking your brains really,
    I have got a customer who wants a home automation system with voice recognition as he is nearly blind. We install Control4 and AMX systems and also many others but have never come across a voice recognition system which can be itegrated into either of these.
    The customer wants control of audio,video, lighting and security, I have seen a couple of systems like HAL however I dont think that I would want to install these X10 systems on a professional level, I feel it is more for the Hobbyists.
    So Has anyone come across any of these systems? Or do you have any Ideas?
    Cheers Guys
    Danny Dawson
  2. TTT
    TTT
    Jun 20, 2005
    +9
    If memory serves me right, you should look at Clipsal C-Bus.
    This will be damned difficult to make reliable! Good Luck!
  3. charris cy
    charris cy
    Apr 21, 2006
    307
    28
    +33
    Danny,
    I also think it would be quite difficult to implement.Of course it depends on what you want to automate.
    Homeseer has voice recognition capabilities. Please look also at the site below of this guy who seems to have achieved a reliable setup using homeseer and voice recognition. Please note though that the mic mixers he is using are for pro use and they are quite expensive.
    http://www.pksweb.com:8080/ha_vr.htm
    Also, the some new touchscreens from AMX have voip capabilities but I am not sure if the voice can be used to trigger commands.
  4. kiruxin
    kiruxin
    Feb 8, 2008
    2
    hal can easely talk to amx via serial...
