Vogels Wall Mount
Discussion in 'Home Cinema Buying & Building' started by cheekychappie, Nov 28, 2010.
  1. cheekychappie
    cheekychappie
    Nov 28, 2010
    Hi there,
    First post but have been using the forums a lot for research over the last couple of weeks!
    I am about to update my old Plasma, for a Samsung eu40c8000 LCD.
    Currently, I have a Vogels EFW2010 Plasma Bracket, which I assume due to its title and the thickness of the Samsung will not work together?
    Can anyone let me know if it will fit my current bracket, and if not, can you recommend a good pan, tilt and swivel wall bracket?
    Thanks,
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
    The title 'plasma bracket' doesn't necessarily mean that it won't fit your new samsung although it's probably a bit bulkier than you need. Also you'll need shorter fixing bolts for the TV (M8 x 16mm). It should fit ok though.
    As an alternative we have our new super slim articulated mount here;
    http://www.m-formonline.co.uk/led-tv-wall-mounts/32-to-55-articulated-led-tv-wall-mount
    This is 34mm deep when pushed back and will give you pull out and swivel (no tilt).
    Hope this helps.
    Regards
    Graham
  3. cheekychappie
    cheekychappie
    Nov 28, 2010
    Hi there,
    Thanks for your post, I will have a look at getting the screws and see how well that works with the existing bracket.
    Cheers,
    Cheeky
  4. cheekychappie
    cheekychappie
    Nov 28, 2010
    Hi Graham,
    Still awaiting the TV to arrive, but in B&Q I could only get M8 x 25mm fixing bolts.
    Do you still think these would be too long? I will have to try and find another supplier if so as that was the shortest B&Q do.
    Cheers,
  5. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
