Flashy
Apologies in advance for waffling on...
Switched to Vodafone broadband yesterday. Old router stopped working at about half-seven, Vodafone kicked in at about 11am. Speed ten times greater than I was getting with old ISP, £276 cheaper over the length of the contract and a free Apple TV 4K. Good.
All working fine, speed as advertised. Great. But an hour later it stopped working. Power, internet and wifi lights on hub flashing white in sequence. I can’t find what this light behaviour means anywhere but there was no connection and the router said it wasn’t connected to the internet.
Turned it off and on again and all was fine. For an hour, when it did it again. This cycle repeats every hour. I tried leaving it overnight with the lights flashing but it didn’t right itself (despite someone on live chat saying it would be fine by midnight...). A restart this morning fixed it and, lo and behold, it went again an hour later.
Spent an hour on the live chat this morning going through the usual script of checking connections and having to send a photo to prove I don’t have a normal Openreach master socket with test socket, just a bog-standard one-port faceplate into which is plugged the micro filter.
Apparently the person could see some drop-outs on the line and that was why it was going offline every hour. Yet when in use for the hours it works it is fine – fast, stable, can stream no problem, etc. I haven’t had any problems like this in seven years in this house with two previous ISPs, although this is the first time I’ve had a FTTC connection
Thankfully the connection went again while I was chatting and it has been passed to the ‘tech2’ team, whatever that is, which will monitor it for 72 hours.
I’ve tried unplugging the Hue hub, swapping to another micro filter, checked all cables, etc., just in case. Anything else I can do/anything it might be? Or am I stuck having to restart every hour while hoping Vodafone can do something?
