VOB files
Discussion in 'Desktop & Laptop Computers Forum' started by djc101, Aug 13, 2002.
  1. djc101
    djc101
    Has anyone sucesfully downloaded a vob file, burn it onto a dvd and played it on a DVD player? Is that even possible? How did it sound?
    Dan
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    You need more than the VOB files from a DVD to make a copy of it.
    You also need the IFO files and a few others too.
    The VOB file contains all the picture and sound info from a DVD so if it's got DTS and DD then the VOB will have them (unless someone has already removed parts that aren't required.
  3. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Yeah, the directory structure really needs to be a "VIDEO_TS/AUDIO_TS" layout to be recognised by the player,with the VOBs, IFOs, BUPs etc correctly ordered and in the right directory. I think you can just use Nero; plonk the VOBs in the VIDEO_TS folder and write IFO's using something like ifoedit.
    I guess you might need proper DVD authoring software to do it correctly. Not sure... :-\
    pAuL.
