VOB files
Discussion in 'PS Vita Forum' started by Darko, Aug 24, 2005.
Tags:
  1. Darko
    Darko
    Apr 13, 2005
    3,695
    Caterham on the hill Surrey
    +173
    Techy question peeps
    I am having some trouble ripping my dvds to put on my psp, I am using dvd decrypter and psp video 9 the problem is that I do not know which file is the movie I have no problems ripping the dvd and no problems converting but which one of the vob files is the right one to convert, is there any way of knowing.
    Please help
    Cheers Darko
  2. chrislad
    chrislad
    May 6, 2005
    5,642
    83
    Rep. of Ireland
    +141
    Use the Stream Processing option on DVDecrypter. The one that's the movie is generally the one that's longer than 1h 30mins. You can set it to decrypt just this part.
  3. grumpyguy
    grumpyguy
    May 11, 2002
    251
    +9
    Its recommended to decrypt the dvd into 1 large vob file. This is done (me thinks) by setting the file splitting option to none, in settings, file mode (right hand side)
    Alternatively, download dvd shrink, and only backup the film, not the crap that comes with it, to your computer. This will also create 1 big file, but again you will have to change the settings to do this. Go into edit, preferences, output files, then untick split vob box. Just tested this, so I know it works.
    I use Rapiz psp video convertor, or 3gp convertor to convert. They seem okay
    Or do as chrislad says
    Anyway, as that guy off Blind date used to say, "the choice is yours"
    Mark
  4. Darko
    Darko
    Apr 13, 2005
    3,695
    +173
    cheers Lads
  5. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,415
    Bristol
    +6,174
    Easiest method is defently using DVD Decrypter, setting it to ouput a single VOB file and then loading that file into PSP Video 9
  6. Darko
    Darko
    Apr 13, 2005
    3,695
    +173
    may sound like a derrr question but explain output a single vob file...
    at the monent I am having to convert 4 vob files per movie is this the way to just have one vob file as the movie if so please go into deph as dvd decrypter has become my nemesis.
    Cheers darko
  7. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    31,415
    Bristol
    +6,174
    Here is how to do it, step by step...
    1. Put in a DVD
    2. Start up DVD Decrypter in IFO Mode
    3. Select 'Tools' and then 'Settings'
    4. Select 'IFO Mode' and from the File Splitting dropdown box select 'None'
    5. Select from the Input box the film (longest running time)
    6. Select a destination to save the file too and then press Decrypt
    When done you will have a single .vob file, its really that easy :)
  8. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,304
    +849
    There are loads of faqs with pictures on how to do this. Just google it :thumbsup:
  9. Darko
    Darko
    Apr 13, 2005
    3,695
    +173
    cool will have a go at this when I get home from work
    Cheers Darko
  10. Darko
    Darko
    Apr 13, 2005
    3,695
    +173
    nice one Indiana Jones I have cracked it
    Cheers darko
