VMS 2000/Eclipse 470 Projector help
Discussion in 'Projectors, Screens & Video Processors' started by john crosley, May 16, 2002.
Thread Status:
Not open for further replies.
  1. john crosley
    john crosley
    I posted the earlier thread about the VMS2000 projector.Having seen a picture of a Maxivideotech Eclipse 470 for sale on Maxivideonline home page I'm pretty sure it's the same projector. If anyone has any ideas where I might find any technical info. please let me know.Nothing available from Maxivideo unless this is similar to the Eclipse 670
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    The Maxi vid are not a projector range I have had any thing to do with.
    But most projector makes follow a similar set up theory. the manual for the next model up is often quite helpful. If you don't have the adjustment they refer to then you know what the model differnces are.
    Worth a go.:)
  3. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,755
    Cheshire
    +108
    Maxivideo projectors were/are distributed by Maxivideo Advanced Systems Ltd in Sutton Coldfield. Try tel: 0121 354 2393 or directory enquiries.
    Regards
  4. Paul Projector
    Paul Projector
    http://www.maxivideotech.it/
    Useful as they have the convergence docs (in adobe format) on there and it has more or less the same procedure for the entire range from 270 upwards (I know as I have a 270 and the manual is very similar).
Thread Status:
