VMR softer than Overlay - 6600GT
Discussion in 'Desktop & Laptop Computers Forum' started by rhinoman, Feb 25, 2005.
  1. rhinoman
    rhinoman
    Oct 31, 2000
    2,670
    71
    Herne Bay, Kent
    +44
    As the title, using Theatretek 2.1 with new renderless mode.
    I have AA set to 0 and AF set to max, FFDshow enabled with a little denoise before resize and then a little sharpness. With overlay the picture is superb with both ripped dvd and hidef. In vmr9 renderless the picture whilst ok, seems to take on a haze, as though looking through a glass film thats not perfectly clear, no tearing or other problems, it just doesn't seem as sharpe or 3D as when using overlay.
    Are there any other settings for vmr that might not be correct?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Odd, since nVidia are generally better at VMR than Overlay .. and reports on TT's forum are saying renderless VMR is sharper than ever. You've set AA and AF as they're supposed to be, especially AA as that's the usual culprit where softening is concerned.
    I'd suggest posting this on TT's forum, I'm sure Vern or Karnis would have some suggestions.
    OTOH, if Overlay is 'superb' maybe it's time to cease twiddling? ;)
  3. Comer
    Comer
    Sep 21, 2001
    1,390
    Ireland
    +86
    That's what I did :smashin:
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,670
    71
    Herne Bay, Kent
    +44
    Thanks guys, re-assuring to know that my settings are likely ok, its just that with the hype around these things we alaways tend to wonder if we are missing out on something someone else has, especially when its a no cost change.....
  5. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    I understand only too well the "if I just try this tweak" syndrome. :) Also knowing that there's supposedly a better result if you do x, y or z. I ditched a 6800GT due to problems with getting reliable refresh rates and reverted to an R9600, in doing so I was supposedly going back to an inferior system. While it's quite plausible the nVidia would improve things a tad the PQ I get with the 9600 is so good that I don't bother about it not being as good as may be possible.
  6. rhinoman
    rhinoman
    Oct 31, 2000
    2,670
    71
    Herne Bay, Kent
    +44
    Having done a nearly side by side (2 different htpc's in the same room feeding a HS20 in turn) of a 9600 in one machine and the 6600 in my machine, at the time we both prefered the picture from the radeon. I have tweaked since and improved things and the pj was calibrated to the 9600 and not my 6600 but even so.....
    I'm sure if both were properly calibrated there would be nothing in it.
