VLC Sound Problem
Discussion in 'Computer Components' started by domtheone, Nov 4, 2005.
  1. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    I have recently installed a programme called VLC media Centre.
    I did this as it appears to play back HD trailers and stuff a lot better than playing them in WM or Quicktime.
    The problem i'm getting though is that a lot of trailers (720p Quicktime files) that i've been playing have no sound, only picture.
    I'm sure it's a VLC problem rather than a corrupt file as when played with Quicktime the audio is there, only the video stutters and lags like crazy :mad:
    Any suggestions :lease:
    TIA
  2. Maff et1
    Maff et1
    Have you checked in the sound/audio preferences to see if it has detected is able to use the correct codec? Make sure you enable select the 'show advanced options' in the preferences otherwise you barely see anything
  3. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    I'll have a look 2night :smashin:
  4. Monty Burns
    Monty Burns
    Jul 25, 2005
    3,874
    Londoner living in Bahrain
    +141
    Ahhh i fell foul of this a few times :D
    When you run some dvd's etc, if they have multiple audio streams attached then it might select the wrong one. When you start the video you should see a list of tracks available in the audio menu. Try changing to another one :thumbsup:
    For the record: I reckon VLC rocks! Don't even need to extract ISO images, it will play from a compresses image... suck on that Media Player! :D
  5. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    I think i've looked at this one and theres only 1 track available :mad:
    I'll double check later to be sure though.
  6. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    Not sure about that, could you put it in laymans terms :D :smashin:
    I've enabled show advanced options though :smashin:
    MB
    I only get 1 choice of audio track and disable :(
  7. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    I''ve been on to the VLC forums and looke dat a thread that covers this issue.
    6 pages of various errors, problems etc etc.
    Some worked, some didn't.
    Seems theres one hell of an issue here.
    I can't sort it so if anyone knows of a definitive fix, please help.
    Otherwise.....well, some files play with sound and some don't, i'll just have to take my chances :)
  8. domtheone
    domtheone
    Nov 23, 2004
    16,323
    Nottingham
    +5,174
    And jsut one more bit of info.
    Take a 720p trailer I have (Serenity) when I play it (audio is fine) the audio options are:
    Audio Track
    Audio Device
    Audio Channels
    Visualisations
    Equalizer
    With a 720p Final Destination 3 trailer I have (no audio) the audio options are:
    Audio Track
    :confused:
