VLC Media Player
readymix
For some reason VLC Media Player has stopped working on my PC i have uninstalled it and tried to reload but my computer will not allow it to install any ideas?????
Deadringers
Right so it is fully un-installed?
you then download the latest release from the VLC website.
double click it to install it...
then what happens?
error message?
if so print screen it and post up here?
readymix
Thank you for the reply,I will check saturday am as i wont be back at the computer with the problems untill then but i will post what is showing.
borrower
There seem to be some problems with 1.1.3, 1.1.4, and maybe 1.1.5. If a reinstall with "clear preferences" doesn't work, you might try reverting.
readymix
All working ok now i ripped some rubbish off my computer and downloaded from download.com reinstalled and working.
