VLC H264 playback awful on top-end system - Advice needed
Discussion in 'Computer Components' started by OggMonst3r, Feb 9, 2009.
  1. OggMonst3r
    OggMonst3r
    Jan 12, 2007
    149
    Portsmouth
    +6
    I have the following:
    Q6600 (@ 3.8Ghz Stable)
    4Gb OCZ 1066Mhz RAM
    Nvidia 8800GTX
    2.25 Tb SataII Hard drives.
    Whilst its not the latest kit, it is still a top performer and have had no problems playing games at high settings or outputting movies to my Sony 40" S4000 1080p via DVI-HDMI...
    Recently however, I've noticed VLC stutters and struggles to play HD content - some movies are fine (The Patriot Blu Ray - 20Gb filesize) but it really cant cope with some scenes on smaller but higher def files such as Planet Earth (2.3 Gb) and Resident Evil 3 (The raven scene)...
    I was wondering if this was VLC at fault?
    If so - could you put your suggestions for alternate media players - and explain what codec settings need using as I'm a bit behind since DivX first came out...
    Ox:smashin:
  2. OggMonst3r
    OggMonst3r
    Jan 12, 2007
    149
    Portsmouth
    +6
    Sorted:thumbsup: Looks to be a problem with VLC - Have now installed SMPlayer - works brilliantly!
    Ox:smashin:
  3. daveaka
    daveaka
    Jun 16, 2006
    1,980
    Willington, County Durham
    +266
    I use Windows Media Classic and the Coreavc codec...
    Ive heard some good things about the DivX 7 media player too
