VLC/Ext usb drive on Panasonic Plasma
Discussion in 'Panasonic TVs Forum' started by ALIEN1X, Jan 10, 2012.
  1. ALIEN1X
    ALIEN1X
    Jan 7, 2006
    487
    +19
    Will VLC potable on a external USB 1TB hardive work if connected to panasonic plasma?
    The reason is, that VlC portable is the only plugin that will open .rec media files/movies, on portable drives/disks etc. Just wanted to know if this will work or will it have to be a powered hardrive for 1tb disk to work?
    Its a real shame Panasonics have no built in vlc so you can play any format.
