VL-900 - repeated commands?
Discussion in 'Home Cinema Control & Remote Controls' started by stroppygoblin, Sep 23, 2005.
  1. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    Can anybody tell me how to learn a command that will repeat when the button is pressed down?
    For example up and down on a sky digibox. The original remote will keep sending the signal when you press the button, causing the menus to scroll up and down. The learned function only does it once, so you have to keep pressing the button to scroll.
    I tried keeping the button pressed down for a few seconds when learning the command. All this does is make the command get fired 5 or 6 time each button press (results in jumping up/down the menus in blocks of 5 - not a good solution if you want to go to the next row!
    All advice gratefully received..
