Vizio P55-C1 vs Vizio M55-E0
Discussion in 'What Is The Best TV For You?' started by strife622, Nov 9, 2017.
Tags:
  1. Vizio P55-C1 for $699
    0 vote(s)
    0.0%
  2. Vizio M55-E0 for $432
    0 vote(s)
    0.0%
  1. strife622
    strife622
    Nov 9, 2017
    5
    4
    Rochester,NY
    Hey all,
    After viewing rtings.com I know the differences between these two models. I'm just trying to justify the extra cost for the P series to see if I really need it.
    Main use of TV
    -Blu ray movies/high def movie watching
    -smash bro's (need low input lag, for SDR anyways)
    I found good prices for both.
    Both refurbished (doesn't bother me too much) from Vizio.
    P55-C1 - $699
    M55-E0 - $432
    So what do you guys think? Would you pay an extra $267 for the upgraded P Series?
    Thanks in advance everyone!
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,613
    +4,479
    Most people who post here aren't familiar with Vizio as they are only sold in North America. I tried to compare but it's hard to differentiate between model numbers. For example it looks like on rtings.com the P55-C1 looks like it's the 2016 P series whilst the M55-E0 is a 2017 model.
    The comparisons aren't accurate though on rtings though because the M series at 55"doesn't use the same panel type they reviewed.
    So with the panel type in mind go for the M series of you need wide viewing angles. If not the P series if you want deeper blacks, higher contrast and better screen uniformity in the dark.
    Looks like the specs on the p series are better overall anyway.
  3. strife622
    strife622
    Nov 9, 2017
    5
    4
    Rochester,NY
    Thanks for the reply and for looking into it.
    I believe the P55 is an IPS LCD so it would probably be ok for viewing angles. I'm more leaning towards the p series...thinking if im going to upgrade from my 42" Panasonic Plasma from 2011, i might as well get the best picture i can.
  4. Dodgexander
    Dodgexander
    May 29, 2007
    15,613
    +4,479
    Where are you getting the panel info from? If you need viewing angles yes you will need IPS. It's a shame though because IPS panels have worse pq traits elsewhere when it comes to screen uniformity, blacks and contrast ratio. Especially compared to a Plasma.
    Why not go for the TCL 55P607 ?
  5. strife622
    strife622
    Nov 9, 2017
    5
    4
    Rochester,NY
    From rtings.com. They mentioned the 55" panel is an IPS panel. This link is for the 2017 version but they also mention 2016 P Series is the same as 2017. Vizio P Series XLED 2017 Review (P55-E1, P65-E1, P75-E1)
    The TCL was my first pick for sure, though I couldn't find it cheaper than $650 and the P55-C1 is only $50 more.
  6. Dodgexander
    Dodgexander
    May 29, 2007
    15,613
    +4,479
    It comes down to viewing angles. The TCL is VA type so you get better contrast and blacks but lose viewing angles.
    If you prefer to have wider viewing angles then I guess the vizio is the better option for you.
  7. strife622
    strife622
    Nov 9, 2017
    5
    4
    Rochester,NY
    Viewing angles isn't as important as picture quality. So if the P607 has a better picture than the P55-C1 then i'll go with that. Thanks for all of your help!
  8. strife622
    strife622
    Nov 9, 2017
    5
    4
    Rochester,NY
    Ended up going with the P55! Found another refurb one for only $599! Too good to pass up.
