Visual C++ Runtime error ............ help please
Discussion in 'Computer Software & Operating Systems' started by smallieboy, Aug 15, 2013.
  1. smallieboy
    smallieboy
    Oct 22, 2008
    4
    Hi all
    I'm running XP on a Compaq Mini netbook that I mostly use for browsing and keeping records while on holiday.
    I generally use Firefox but had to 're-enable' IE (- 7, I think) as a site I was looking at didn't support FF well. Since then I've had runtime error's popping up at, what seems like, totally random times (including, for example, during startup and shutdown!). The message I get is
    Microsoft Visual C++ Runtime Library
    Runtime Error!
    Program: C:\...
    This application has requested the Runtime to terminate it in an unusual way.
    Please contact the application's support team for more information.
    As you can see, it doesn't actually tell me which program/application is causing the problem.
    Has anyone got any ideas how to sort this please? I've re-installed IE7, updated to IE8 and even updated Visual C++ all to no avail.
    I don't store anything much on the PC so can do a restore back to original settings but it would be a pain in the a$$ to have to do so.
    Thanks in advance
  2. maddogb
    maddogb
    Apr 11, 2009
    1,647
    63
    Cumbria
    +195
    try a scan with malwarebytes see if it picks up anything dodgy, runtime errors can also be caused by failing memory and many other hardware issues so try a few runs with something like memtest.
  3. smallieboy
    smallieboy
    Oct 22, 2008
    4
    Hi Maddogb
    MWB and memtest showed no problems so I tried a restore using the Roxio Back on Track utility that HP put on instead of a restore partition. Can't really tell it's done anything - everything looks exactly the same and I still get the error messges. Looks as if my only option is to see if I can find a way to reinstall XP - trouble is, no CD's cos HP don't supply them with netbooks and I don't trust Back on Track to have produced a proper restore 'set'.
    Perhaps I'll go and buy an Android tab!
    Thanks for the help
  4. smallieboy
    smallieboy
    Oct 22, 2008
    4
    Maddogb - not sure if you'd know the answer to this but someone suggested removing and reseating the memory; do you think this is a viable solution?
    thnx
  5. maddogb
    maddogb
    Apr 11, 2009
    1,647
    63
    Cumbria
    +195
    if there was a serious enough error and it was because of bad seating/poor contact i would of thought memtest would of picked that up using the same address repeatedly.
    Saying that, a quick clean of contacts will never do any harm as long as antistatic precautions are followed and a "clean" solvent such as ethanol or similar is used.
    At the level Visual C operates at i would expect it to be more likely there is a software error here, otherwise hardware tends to produce more "random" errors not just in a single library of code as you are describing.
    It might be helpful to post more details on the hardware, i suspect its simply a bad call from a program running at start up /and or on a schedule so use msconfig to remove all non ms stuff from starting up (services and startup items, also disable the ms scheduler.
  6. aa1xxbb2zzzz
    aa1xxbb2zzzz
    Sep 1, 2013
    2
    hi i am new here.
  7. smallieboy
    smallieboy
    Oct 22, 2008
    4
    Hi Maddogb
    I haven't used the netbook for a few days and the battery ran completely flat. Recharged it and by a strange coincidence I've had no problems since - I doubt the two are connected but (for the moment) the problem seems to have gone.
    Thanks for your help.
  8. aa1xxbb2zzzz
    aa1xxbb2zzzz
    Sep 1, 2013
    2
    congrats your problem solved...........
