Vistron DB26-BD won't hold picture settings
Discussion in 'LCD & LED LCD TVs Forum' started by MacSporran, Aug 7, 2013.
Tags:
  1. MacSporran
    MacSporran
    Aug 7, 2013
    Hi folks! New to the forum, so please be gentle,
    My neighbour has a 5-year-old Vistron, which has defaulted to a 4:3 picture. When I go to picture setup, I can change to "Panorama" or "Auto" without any problem. The trouble is, I don't see a way to hold or save that setting, consequently, when restarted, it has gone back to 4:3.
    This seems like an easy problem to solve, but the manual doesn't help, therefore hopefully, someone here will have the answer. TIA.
    Mac
  2. JayCee
    JayCee
    Jan 20, 2004
    23,504
    Lanarkshire
    +2,534
    The aspect ratio should be left at "Auto", that way a widescreen 16x9 programme will fill the screen and a 4x3 programme will be viewed the way it's meant to.
    You haven't stated if all programmes are viewed from the set's internal tuner or does he have an external box such as a Satellite receiver or Cable Tv, PVR etc.
