Vistron 32" LCD - vertical bands at edges - help!
Hercule
First post here. Can anyone advise likely fix to resolve the following problem?
65mm wide green vertical bands have appeared at both of the outer edges of the picture.
Mark
JayCee
More info is needed?
Is it a widescreen set?...are they present on all aspect ratios?
Hercule
Thank you for taking an interest.
It is a widescreen panel. It does not appear to be present in normal (4:3) format, only widescreen (16:9) viewing.
