Vista Ultimate Boot Up Errors
Timh
Hi, my son has had vista working on his computer for a few days now however when he booted it up this morning it came up with a few errors.
"logonUI.exe - Bad Image
C:\windows\system32\shgina.dll is either not designed to tun on windows or it contains an error."
He also has the same error but saying "system32\oleacc.ddl" instead.
After this the computer shows the vista logo and then goes to a black screen and stays that way. When he boots into safe mode he gets the same error but can get onto the desktop. From there he can only browse his files and launch internet explorer 7.0 He cannot launch any other programs such as Avast as they come up with errors such as "ashAvast.exe - Bad image".
He ran a program called "Stinger" which checks the computer for virus's but it showed that the computer was clean. From there he has put his vista disk in and attempted to repair the windows, and also go back to an earlier restore point when the computer was running fine but nothing has worked.
He checked his processes under task manager and the only things running were:
csrss.exe
Explorer.exe
Taskmgr.exe
Winlogon.exe
Does anyone have a clue on how to fix this problem?
Singh400
Ah your son has been trying to install a customized logon UI screen and gone wrong badly.
LogonUI.exe and shgina.dll both contain image resources that related to the logon screen. Some people replace those image with custom ones. Then rebuild the exe and dll files and offer them up for download.
Hopefully, before he replaced the original files with the hacked ones he made back ups. But I don't think he did that.
You need to replace the hacked files with the original files.
You can find the original version of logonui.exe here:
C:Windows\winsxs\x86_microsoft-windows-authentication-logonui_31bf3856ad364e35_6.0.6000.16386_none_635c5092764d99de
You can find the original version of shgina.dll here:
C:\Windows\winsxs\x86_microsoft-windows-shgina_31bf3856ad364e35_6.0.6000.16386_none_c640714022f92de8
I've no idea what oleacc.ddl, so I'm gonna assume you mean oleacc.dll. You can find the original version of oleacc.dll here:
C:\Windows\winsxs\x86_microsoft-windows-oleacc_31bf3856ad364e35_6.0.6000.16386_none_684dfbd22578aaaf
You'll need to boot into safe mode to replace those files.
You might want to try last know good configuration before you try the above. Might save you some hassle. You can access that from the same screen as safe mode.
Timh
Thanks, he is going to attempt what you recommended doing.
I don't suppose windows blinds could have caused this problem?
Timh
Found the files but Vista will not give permission to replace the files in safe mode. :(
echrada
Use your vista disk to boot with and go to repair and then system restore and restore it from there to an earlier date preferably 5 days before.
Timh
Tried that :(
Decided to format now.
Singh400
Yes it could have.
Try killing explorer.exe and just replacing the files via cmd. If that doesn't work you'll need to disable WFP.
Timh has already stated that this method was tried and it failed.
