Vista Task Scheduler for sleep/wake events
s.t.s
I am trying to get Vista to run a .bat command to turn my TV on/off as it wakes/sleeps from normal sleep mode or when powering on/off fully. I have an admin user and non-password protected "Media" user so the user log-on/log-off doesn't work since I need the TV on to select user etc.
Anyone have any good ideas?
Using event monitor I found a few events that occur at sleep and wake but for some reason they don't seem to work when I tie the bat file to them?
Synchro
Power settings will allow you to set whether you want your monitor to switch off or not. If this not good enough?
s.t.s
It would be if my LCD TV (as this is on my HTPC) paid any attention to that ;) but sadly it doesn't, hence the RS-232 serial control angle I am taking on it
s.t.s
That is an interesting idea ... but my TV would still need interaction to wake it from standby and select the correct input so I think I still need to work out how to tie these actions to the correct events :(
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
