VIsta and XP in same PC
Discussion in 'Desktop & Laptop Computers Forum' started by mirzaair, Feb 12, 2009.
  1. mirzaair
    mirzaair
    Dec 3, 2008
    39
    Hi All
    I have a Quad core desktop with VIsta. For obvious reasons, i would also like to use XP. SO I would like to know:
    1. Having two OS in one PC, is it going to make my pc slow?
    2. Is there any known problem of having two OS in one pc?
    IF NOT then:
    3. How can I have install XP home in my Vista PC
    4. I would I quickly switch between two OSs during startup.
    Thanks in advance folks.
    R
  2. Mr Lazy
    Mr Lazy
    Jan 14, 2008
    1,026
    Rochester, Kent
    +144
    No, each OS will behave as if it was a computer in it's on right.
    Not really. So long as you don't mess too much with the partitions, boot loader etc.
    No-ones going to tell you here how to do it - it would take too long, but google is your friend. Try this: Dual Boot Vista and XP with Vista already installed - SysChat
    Windows will prompt you at boot up (after the BIOS bit) which OS you want to boot - this is setup as part of the install process.
    If you really want to know what's going on have a read of this:
    http://www.multibooters.co.uk/multiboot.html
  3. booyaka
    booyaka
    Sep 26, 2002
    11,062
    +3,584
    simple and straigtforward if you follow the links above.
    i have my laptop dual booting to Vista and Windows 7 beta.:thumbsup:
  4. Mr Lazy
    Mr Lazy
    Jan 14, 2008
    1,026
    Rochester, Kent
    +144
    Yep, currently triple-booting Vista 64, Windows 7 Beta and Linux :smashin:
    Could do with moving the partitions about though to gain an extra logical partition and use some unallocated space.
  5. mirzaair
    mirzaair
    Dec 3, 2008
    39
    Thanks everyone I will install XP and Windows 7 in my PC. I have good space in my HDD (1.5 TB) and 4GB RAM hopefully won't be a problem then.
