vista advice please on deleting registry!!?
Discussion in 'Computer Software & Operating Systems' started by Cool-hand, Jan 21, 2008.
  1. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Can anyone help please!? Everytime I start vista I get a warning box pop-up advising me
    'could not load or run c:\users\top\appdata\local\iiffd.exe specified in the registry. make sure the file exists on your computer or remove the reference to it in the registry.'
    I can find the registry entry (or at least I believe it is), it states its a load file in regedit. But after ive delete it and restart vista its back again!!!!
    What should I do??
    Many thanks to anyone who can help me solve it :)
    Rgds
    CH
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    Have you got spybot search and destroy?
    There are a couple of tools that might help (system internals & system startup) in the advanced mode (tools). Make sure you back up the registry etc,. before deleting anything. Also before you unclick anything research it first.
