Vista 64 Bit and installing BTs Antivirus
Discussion in 'BT Broadband' started by lordstew, Jan 17, 2008.
  1. lordstew
    lordstew
    Jun 11, 2006
    57
    Has anyone been able to install BTs free version of Norton antivirus onto a PC using Windows Vista 64bit edition?
    It doesnt show up as an install option from BTs page but Norton is compatible with vista 64bit if you buy the retail version.
  2. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    The BT Norton Internet Security package is not yet compatible with 64 bit OS, sorry - will try and get a progress update as to when it will be.
  3. lordstew
    lordstew
    Jun 11, 2006
    57
    Has anyone got an update on this? Is there a workaround or does BT have any plan to support Vista 64bit?
