K
kubik
I´m using the vision together with Panasonic plasma TH-42PW5
(852x480)connected with VGA-VGAcable in RGBHV mode.
I have a satellitebox connected with s-video cable,can also connect it with
component cable but same result:
Looking at a scoccer match(european foodball) from the sat-box, the picture
looks the same as before without the vision,with waves on the horisontal
lines
and the goal and the circle when the camera is panning vertical. Maybe this
is normal because of small scanlines, video-mode,the poor quality picture
from tvprogram/sat-box.
Normal television sets with antenna or cable looks the same.I was just
hopeful that the vision could fix that.
An other thing I noticed was ghosting on fast horisontal movement.There are
coming 2-3 extra lines from objects.
When I look at news the have small rolling text down in the picture.When I
zoom the picture, the text looks 3-D.The letter "L" gets 2 extras
ll,vertical lines on the right side.
When I zoom in test picture or OSD(on screen display) I look on a vertical
line,there are 2 extra lines to the left and 2-3 more visible lines to the
right.
Sharpness control on plasma is zero same on the vision.
I have tried to ajust the clock phase on the plasma , dosent help.
Also tried to ajust h sync pulse on vision , menu 0940 dosent help.
Is there any other memu I can try to ajust to make the exrta vertical lines
to disappear ?
lines
right.
to disappear ?
