Question Vision V20-105 Mast Amplifier
Discussion in 'Freeview & YouView' started by northern cookie, Jul 3, 2015.
  1. northern cookie
    northern cookie
    Jul 3, 2015
    3
    Thurso, Scotland
    I have just moved into a new house and am having difficulty getting my freeview HDD box tuned in. I have an internal aerial in the loft connected onto a Vision V20-105 Mast Amplifier. Am i right in thinking that i need a PSU plugged into one of the aerial wall plates (which the previous owners appear to have taken away with them?
    If so, anybody now which one?
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    If the power supply is missing it can easily be replaced by a SLX masthead power supply from Maplin for £19.99. Simply connect it to your aerial lead at the TV set end. Similar power supplies are available elsewhere.
  3. TJT1
    TJT1
    Jul 29, 2011
    4,820
    East Sussex, UK
    +1,139
    Before you go shelling out on a PSU, first check to see if the box has got a 12V output at the aerial skt. Some do. (to run masthead amps:D)
    Maplin's PSU mentioned above is a bit on the expensive side. Google is your friend.
  4. northern cookie
    northern cookie
    Jul 3, 2015
    3
    Thurso, Scotland
    Neither the TV or the HDD box have 12v outputs on the aerial skt. I've had a look around and there are a few psu out there (including a vision one, - google really is my friend) but they are all 12v 100mA. My amplifier has input: 12v 55mA marked on it. Can i still use the 100mA?
  5. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    The answer to that is yes. The amplifier will only draw the current it needs. TJT1 is quite right in saying that the Maplin one is a bit expensive. I bought one years ago and it was a convenience that I could pick it off the shelf. Screwfix is another store you may have and they sell a Labgear brand at a more realistic £11.46.
  6. northern cookie
    northern cookie
    Jul 3, 2015
    3
    Thurso, Scotland
    Thanks very much guys. I've gone with a Vision PSU - £11.99 from Amazon. Hopefully this will fix it.
  7. TJT1
    TJT1
    Jul 29, 2011
    4,820
    East Sussex, UK
    +1,139
    That'll be OK.
